08-14-2025
11:49 AM
08-14-2025
11:54 AM
computergeek541
new client - how sim will work ?
I am going to transfer my existing number( port ) to public mobile.
what is the process ?
i m from niagara falls ontario , is there any physical location , where i can get it setup ?
08-14-2025 01:03 PM - edited 08-14-2025 01:04 PM
You can order a SIM from Amazon for $5 and faster shipping.
The steps must be followed in exact order if you are porting your number over to PM:
08-14-2025 12:38 PM
Thank you !
08-14-2025 12:26 PM
08-14-2025 12:26 PM
@MaxCell you have to do it all yourself, no booth, no physical locations.
So beware that everything will need to be done online through the self serve account by you moving forward if you choose to proceed with the services of Public Mobile with assistance through this Community or Public Mobile agents.
You think you will be ok with that?
08-14-2025 12:09 PM
okay , there is no physical location ? like small booth etc..
08-14-2025 11:56 AM
@MaxCell wrote:new client - how sim will work ?
Public Mobile SIM cards can be purcahsed from Telus stores, specifically the ones that are owned and operated by Telus, but the staff at these stores cannot assist with activation. To activate, you'll need to install the Public Mobile smartphone app. The app will guide you through the setup process.
