05-09-2022 06:34 PM
05-09-2022 08:33 PM
@Humphrey - are you trying to add a new card on your account?
If you never registered for a self serve account, you can register for one here: https://selfserve.publicmobile.ca/self-registration/
Then once logged in, navigate to the PAYMENT tab and update or replace your card on file:
05-09-2022 07:18 PM
Only through personal mail:
To contact CSA, there are 2 methods:
05-09-2022 07:10 PM - edited 05-09-2022 07:10 PM
PM is an online carrier but most issues could be help by this Community.
You will need to contact a CS_Agent for PM staff to help you through private messaging.
You can contact them via private messaging or create a ticket via SIMon Chatbot.
What is your problem?
05-09-2022 06:38 PM
HI @Humphrey
PM support is all online. YOu will need to open ticket with them and work with them via messaging here
To open ticket with CS Agent, at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
