new activation
Dmartinez
I am unable to active my sim card it keeps saying that there is an error
7 REPLIES 7
Great, they should respond within 4 hours depending on volume.  Just watch your inbox for their reply. Could be untill tomorrow.  Upper right corner of your avatar.
Dmartinez
I have Sumsung, i tried sending a private message down to the CS agent.
Dmartinez
The message says " We encountered an error processing your request. this may be due to a system error, please go back to the previous page and try again. (Error Code: XXX)"
@Dmartinez
did you activate physical sim or esim? you have an iPhone?
try this,
  1. Click Logout on top left of the screen
  2. Wait 5 mins for the system to configure on the back end.
  3. Then log in again using the Email  and Password.
  4. The app will then  sends a code to the Email again,.  Enter the code
  5. and you will see the prompt  'Confirm for Full Access' and your Activation will be completed after
if that does not work, open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
Dmartinez
at step 6 it then gave me the error it said " we encountered a problem..." to go back and I did go back but unable to do anything else
@Dmartinez give me more information, at which steps you had the error?
Step 4 payment?
step 5 phone number?
or step 6 finishing activation?
and did you use the PM app to activate?
Sansan
What is the error?
