02-13-2019 06:42 PM - edited 01-05-2022 03:21 AM
02-13-2019 07:07 PM
For income tax purposes, if you e-file your return you need this as backup in the event there is an audit.
You can can print the info upon logging into your PM account.
Cheers,
MJ23
02-13-2019 06:55 PM
@wooz You can print your transaction summary from your account by date.
02-13-2019 06:44 PM - edited 02-13-2019 06:45 PM
Ok for n receipt you will need to contact the moderator directly @wooz here...
and explain what you need..you will need to wait for a reply few hours upto 2 days...they will answer you...![]()
