need help please
danieladicu
i have not received any phone calls in a while, i think something is wrong with my phone,
Dunkman
@danieladicu
Is your account status active versus suspended?
You can also try your SIM card in another working phone.  That would help determine whether phone issue versus PM service problem
MrSpock
@danieladicu hi do your calls go to voicemail, is do not disturb enabled? can you make outgoing calls
RossN
@danieladicu hi does anything else work,texting , data? what plan are you on ?
