01-11-2026
08:36 PM
01-11-2026
09:08 PM
computergeek541
My umidigi phone wont get data since I had to do a factory reset, this has happened before and it worked after it was reset on the public mobile side. same when i first bought it.
01-11-2026 08:55 PM
you can make an APN change yourself and it will work without PM agent resetting it
Compare the APN settings below, try to update it and save:
APN: SP.MB.COM
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D (or try: 4D4F)
01-11-2026 08:39 PM
Thank you
01-11-2026 08:38 PM
to engage with Customer Support, click the orange bubble on lower right side of the page to start the process.
