my puk code
WDG
Can i verify my puk code before i try putting the simm from my new iphone into my old iphone
i have a puk code do not know it it has ever been changed
1 REPLY 1
@WDG SIM PUK is an unlock code to be used after the sim is locked
If you meant the SIM PIN code instead, you can go to the phone settings to disable it and you will then be asked to enter the sim pin and you will know if you got the correct pin ( From Settings > Cellular )
If for any reason your sim is locked and you need a sim PUK, please reach out to PM CS agent
Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
    (if unable to receive 2FA via SMS, click "Didn't Receive code" or "Resend Code",
     then choose "
Send email" or "Send Voice Message" to get 2FA via email or voicemail)
