09-23-2019 01:00 PM - edited 01-05-2022 09:18 AM
09-23-2019 04:38 PM
@tashy110787 wrote:bought from 7-11 and my pin not working @moderator
Some of the time, these top up vouchers are not instantly activated in the computer system. It's possible there might be a 1 day delay.
09-23-2019 02:20 PM
@tashy110787 try Adding the voucher by dialing 611 from your phone. Make sure you are using the correct PIN number.
09-23-2019 01:12 PM
Also you should double check your self serve account page or just call 611 again to see if the voucher had been already put into your account the first time you entered the pin, it happened to me once and I thought it didn't get put in and it was actually. I even put it the wrong number from my voucher before thinking it was the pin, then realized I put in the wrong number that wasn't even the pin.
09-23-2019 01:06 PM - edited 09-23-2019 01:08 PM
To submit a ticket to Moderators. Click on the green Question Mark (at bottom right).
Type "submit a ticket" and "contact us" to get started.
What's the issue exactly? Perhaps we can help.
Did you buy a voucher and it's not working?
