05-12-2020 06:54 PM - edited 01-05-2022 10:45 AM
broke my umidigi a3x ordered a new one and this one will not connect to my data what so ever only wifi . im no tech guy can anyone help.
Phones
08-25-2020 12:58 PM - edited 08-25-2020 01:01 PM
I have the same phone and tried the accepted solution, but it didn't work... Furthermore I had MMC proxy option instead of MMSC proxy.
In the end I had to set the APN settings as in this post: https://productioncommunity.publicmobile.ca/t5/Getting-Started/Samsung-Galaxy-A50/m-p/400387/highlig...
I set the MMC proxy at 74.49.0.18 just as the MMSC proxy would have been.
Works!
05-13-2020 07:28 AM
Thank you. What you said worked out.
05-13-2020 07:27 AM
Fixed it . And they are great phones for there price .
05-12-2020 07:16 PM - edited 05-12-2020 07:16 PM
05-12-2020 07:09 PM
@jamie905, maybe don't buy a umidigi a3x phone!
05-12-2020 07:01 PM - edited 05-12-2020 07:06 PM
@jamie905 hi make sure your data is enabled try these settings
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
Select Save/Done. Select Public Mobile to connect to the Public Mobile network
