03-11-2025
04:44 PM
03-11-2025
09:05 PM
computergeek541
I subscribed with esim option but it isn't supported by my phone. I bought a physical Sim from Amazon but can't activate it as I just get stuck on the page where it tells me my phone isn't compatible.
03-11-2025 09:07 PM - edited 03-11-2025 09:09 PM
@BKNS27 wrote:Are you using the PM app to activate the SIM?
You need to activate the new SIM on the app.
The customer reports that the activation system is saying that the eSIM can't be used on that phone. While the app does need to be used to finish actvation, the device incompatibility isn't related to that. An account change at this points requires a CSA.
03-11-2025 05:17 PM
03-11-2025 05:00 PM
Did you pay when you first tried to activate with esim? If you did, you can ask PM to check and update sim card for you
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
