10-13-2022 02:53 PM
10-13-2022 03:40 PM
HI @Hanic no need to "activate", it is there
Has it been 30 days yet? If so, you might consider to do a refund first and buy another one after
Either way, open ticket as advised above. Once they have the ticket, they will tell you where to bring for service.
10-13-2022 03:35 PM
Check if your phone is compatible with PM first: https://publicmobile.ca/en/bc/get-help/articles/check-your-phones-compatibility.
If not, change your phone.
If yes, try your phone with other sim cards. If other sim cards are not working as well, return it. If other sim cards are working, contact PM for a new sim card.
Hope it helps😉
10-13-2022 02:59 PM - edited 10-13-2022 03:00 PM
@William16 , this is the help article concerning troubleshooting phone problems. Give these a try first. Maybe the issue is small.
https://www.publicmobile.ca/en/on/get-help/articles/phone-troubleshooting-tips
10-13-2022 02:59 PM
Is this a certified pre-owed phone purchased from Public Mobile. If you've had it for less than 30 days, you can return it for return or exchange. Please open a ticket using the chatbot and ask a customer support agent for help: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If you've had the device longer than 30 days, Please contact a Telus retail store that handles warranty issue or contact Mobile Klinik for warranty repair options.
