01-15-2020 10:06 PM - edited 01-05-2022 09:02 AM
hi! I wanted to know if the Motorola action one works with public mobile network?
01-25-2020 01:55 PM
@dian_34 If you're concerned, ask the kiosk/store to put in a PM test SIM before activating if opening your acct in person
01-15-2020 10:19 PM - edited 01-15-2020 10:26 PM
Also see this thread with others confirming it is compatible.
01-15-2020 10:09 PM - edited 01-15-2020 10:11 PM
Yes it will based on the specs.
