03-08-2024
12:06 AM
03-08-2024
03:58 PM
computergeek541
03-12-2024 05:14 PM
My wife has a Pixel 4a and it worked properly for RCS however any iPhone MMS or group messages would not download for the past couple weeks.
Tried all the troubleshooting and savings settings many times.
I JUST got it to work and it was such a simple change....
APN protocol changed to IPv4 (when it was set for IPv4/IPv6 it didn't work)
Go to Settings > Connections > Mobile networks > Access Point Names
Press Add on right top corner. If your phone has already set values for Mobile Internet for any fields below leave them.
Change the other fields as below.
Name: Public Mobile (or whatever you want to call it)
APN: sp.mb.com
Proxy:
Port:
Username:
Password:
Server:
Multimedia message proxy: mmscproxy.mobility.ca
Multimedia message port: 8799
MCC: 302
MNC: 220
Authentication type:
APN type: default,mms,supl,fota,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
Restart your phone to apply new Mobile Internet APN settings.
03-08-2024 12:09 AM
@LeeJ1 check this message to see if it applies to you.
Might need to update the APN settings.
03-08-2024 12:09 AM
J7 was released back in 2015 and could be affected by this announcement
if you are using a device that released after 2017, generally, you can simply click Reset All networks or Reset network settings to get the latest APN
Also, you can make a manual update, here are the old and new settings
Old settings:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
