04-15-2019 12:59 AM - edited 01-05-2022 07:12 AM
Hello sir
My niece registered her mobile phone xxx-xxx-xxxx under my name but in her email
address [email protected] payment came out from her debit account in Royal bank
In March 23,2019 my niece became disoriented and lost her mobile phone.
When i tried to help to access her account, it was not able be accessed.
Please help! Advise me what to do in this case as to how to suspend or cancel her service
Thank you
(edited by computergeeek541 to remove personal information)
04-15-2019 10:20 AM
I suggest you reach our to a Moderator directly asap, get the line shut down and get your account access restored.
Good news is that they can't do more damage other than use up your pre-paid data & air time.
BUT - I would not want anyone using my phone number for what might be not so nice things.
GL, hope your neice is okay....
04-15-2019 10:20 AM
when i put in forgot my password the system said invalid email
04-15-2019 10:19 AM
i did put in forgot my password
and the system reply that the e -mail is invalid
I wish the system will reveal at least the correct email address
04-15-2019 01:14 AM - edited 04-15-2019 01:16 AM
@anitalau , I have changed your message to remove contact information because your rmessage is viewable to anyone with a working internet connection.
If you haven't already tried, I would go to selfserve.publicmobile.ca and try the "forgot your password?" option. You will need to know the answer to the security quetsion for this option to work.
Assuming that you are then able to get into the account, you can then have the phone reported as lost so that someone else can't continue to use the service.
04-15-2019 01:10 AM
Have you tried the "Forgot your password link" on the login page?
You need the account email address and the answer to the security question to reset the account pasrword.
Send a private message to moderator for help if you forgot the answer to the security question.
04-15-2019 01:03 AM
