12-18-2019 04:45 AM - edited 01-05-2022 08:35 AM
12-18-2019 05:39 AM
okay I put the public mobile
now wish me luck with VPN
12-18-2019 05:24 AM
I do not see public mobile anywhere. I have done many attempts with plenty of data and wi fi off
12-18-2019 04:52 AM - edited 12-18-2019 04:56 AM
@dboxtvinfo715 wrote:
Changed my phone and now my data don't work.
@dboxtvinfo715What kind of phone is it? Be specific. To be able to check for compatibility.
Make sure the data is on, and you have data left in your self serve account overview. Most likely you need to update the APN settings/search for the network manually.
In your phone settings under Mobile Network --> Carrier --> select Manually search for network and click on Public Mobile
For APN, it would be under Mobile Network --> Access Point Names
Add a new APN and enter the Public Mobile details -->https://apn-canada.gishan.net/en/apn/public-mobile
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
