08-01-2023 10:21 AM - edited 08-01-2023 10:22 AM
Hi. I can't seem to log in to my account. at first it kept saying that the password is incorrect. I changed the password. but it seems like I do not have an account. after logging in, i get the message to complete activation. and 2 options. resume activation or go to login. if I click on go to login, I am just redirected to login page and then the same page shows up. it's just a loop. and if I go to resume activation, I am asked to select a SIM. I chose the option that I already have a SIM. then I am asked to enter the SIM number. and I get the message that the SIM is Invalid. I have been a public mobile user since 2018. but it looks like my account is that of a new user who needs to buy a subscription. I have tried logging in through mobile app. but I got error saying: Unknown request failure. I am out of country for now. I reset my password with email by clicking on resend code since I can't receive any calls and texts out of the country. I want to keep my number activated. thanks. please help me.
02-24-2024 11:26 AM
Hoping you have fixed this issue but for anyone else searching for this problem, the same was happening to me yesterday when I was starting my account up. It seemed to be stuck in Step 5 and after trying to activate the SIM Card over and over the app started logging out and just going to the login screen. Once I submitted a ticket the CS_Agent was able to help finalize tha account (it sounds like everything was activated behind the scenes for them but glitching and showing me it wasn’t activated). Once the account was actually activated with the help of the CS Agent, I had no problems logging in! If anyone finds them selves in this situation go to Public Mobile community and send a private message to CS_Agent:)
02-24-2024 11:26 AM
09-03-2023 01:09 PM
Lol, isn't this great customer service! And to think we pay for this!
08-16-2023 09:26 PM
I have same problem , How do you shoved it
08-02-2023 08:29 AM
Yes I did. still no reply. I am sending another message.
08-02-2023 08:27 AM
usually within an hour or two, did you check your community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) ?
If you opened one yesterday and still no reply at all, I would suggest to message them again.
08-02-2023 08:05 AM
How long does it take to gat a reply back? I haven't receive any response yet.
08-01-2023 10:44 AM
Thanks, on it
08-01-2023 10:43 AM
yes I have already contacted them.
08-01-2023 10:40 AM
It sounds like you need assistance from a CS_Agent (Moderator). Click on the envelope icon on your computer and private message them for help accessing your account.
Eversafe ID will merge your Community email to your account email if they are different.
08-01-2023 10:30 AM
@aimen114 wrote:I tried. but now it says that an ID with my email already exists
you need to engage support at this point, message them
08-01-2023 10:28 AM
08-01-2023 10:25 AM
did you ever able to login My Account successfully since the introduction of EverSafe?
If you were able to login before since EverSafe was used, then please try using Incognito mode to log in again
If it is the first time you login with EverSafe, it could be just system issue with account.
Please message support to sort it out
08-01-2023 10:24 AM
Did you register an Eversafe ID before login?
This is new to all new and old members starting last month.
Click on Sign Up then login.
