locked out
Jonijohn2
Forgot which email I used.  Mixed up the passwords. Tried to reset them. Now I am totally locked out and going in circles
2 REPLIES 2
RossN
@Jonijohn2
did you try clearing your cache use a different browser in ingognito or private mode also try a different device to log in if that doesn't work
contact a cs agent they can fix your email issue
1.  you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
Timer
@Jonijohn2
use browser from computer,and clear cache and cookies and use one page inPrivate mode,
Trouble logging in? then  Reset Password
or contact support team by CS_Agent  to change email and set new password.
