lock the data
1zzaman0
i want to lock or stop my data when its over the limit
SomeFriend
Just to add to a post above me, Public Mobile sends a data usage alert via SMS when you use over 75% and 95% of your allowance.  It’s not always on the spot however, I find there’s a slight delay.
There’s no alert at 100% used, your data services will just be suspended and any attempt to use it will direct you to the “zero balance” captive page.
Haiggy
As a prepaid service, Public Mobile will not be charging you after ("post") your usage - if you try using more than you paid for, it will just halt instead until your next top-up payment.
Jonaldc
Hello 1zzaman0,
Public Mobile also sends you a text message when you are almost at your limit (at 75% I believe). Furthermore, you can also set up your phone to give you data usage warnings by following the below steps.
Andriod:
Settings>Data Usage>Turn on mobile data
From here you should see different options for mobile data
Hope this helps!
Dunkman
@1zzaman0
You don't need to worry about data overages.  Once you run out of data, your data will just stop.  No extra charges.
