07-19-2020 06:26 PM - edited 01-05-2022 12:10 PM
I am having issues with renewing my plan. I changed my plan from the $40 option to the $35 option and I have replaced the credit card details. Unfortunately my account has been debited with the sum of $9.20 without any reactivation of my account. What is the way forward because I need my plan activated and then I want the $9.20 refund.
07-20-2020 08:56 AM
When changing from a higher priced plan to a lower priced plan it's best to have the funds in your plan to cover the higher priced plan ($40 in your case) because of a bug with the PM renewal system sometimes it will fail.
07-20-2020 08:33 AM
@dome wrote:Thank you,. This worked pretty well for me 'cos I was connected via private messages to a moderator who explained what the issue was and also helped resolve.
@dome In the interest of everyone learning something it might be helpful if you explained what happened and what they did to resolve it.
07-19-2020 08:18 PM
07-19-2020 08:11 PM
A few more details please.....which account has been debited $9.20? Since your self serve account works mostly in round numbers that amount sounds like your bank or credit card account.
If you are trying to reactivate after suspension due to an autopay failure as mentioned by @geopublic you must add the amount of funds owing then reactivate the system doesnt automatically charge your card (except the one time during renewal) you have to manually add the funds yourself. Then click on reactivate then reboot your phone. Do all of this with a clear browser, in secret/incognito mode on Firefox, chrome or safari.
07-19-2020 07:54 PM
Hi @dome
Would be helpful to take a look at your payment history and up know your account balance.
To switch plans immediately you must first put money on your account
If your account is suspended you should reactivate your account by clicking the reactivate button.
It may take you to payment option, if you have enough funds then add one dollar and proceed
You will need to restart your phone
07-19-2020 06:36 PM
@dome wrote:I am having issues with renewing my plan. I changed my plan from the $40 option to the $35 option and I have replaced the credit card details. Unfortunately my account has been debited with the sum of $9.20 without any reactivation of my account. What is the way forward because I need my plan activated and then I want the $9.20 refund.
@dome When changing from a higher priced plan to a lower priced plan it's best to have the funds in your plan to cover the higher priced plan ($40 in your case) because of a bug with the PM renewal system sometimes it will fail.
Best to submit a ticket to PM explain what happened and ask them to fix it. To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking here or the icon (bottom right of your screen).
If you are still having problems contacting Public Mobile then click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
07-19-2020 06:33 PM
@dome your plan may be stuck mid change. Contact the moderators and ask them to fix it for you. There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
07-19-2020 06:31 PM - edited 07-19-2020 06:33 PM
@dome is the $9.20 is available funds. just add total available funds of $35 to reactivate your account
