08-22-2023 12:52 PM
I’ve been trying for almost two days and it just keeps telling me my services are disconnected
08-23-2023 07:09 PM
need help
08-22-2023 01:10 PM
@CS_Agent wrote:Hello there,
And thanks so much for sharing your concern with our community, we hope that you have the answer that you need, in case you still need assistance, please keep an eye on your community imbox,
It could be that one of our customer services representatives has already reply to your private message.
thanks @CS_Agent
@Destiny01 please check your Community inbox and agent would resolve this for you
08-22-2023 01:09 PM
Hello there,
08-22-2023 01:09 PM
@Destiny01 wrote:I’ve been trying since yesterday and I got it at my local circle K
HI @Destiny01
voucher from Circle K should be good
Try loading again using My Account with Incognito/Private/Secret mode, or try to use *611 or 1-855-4PUBLIC to see if you can load the voucher
If not, just submit message to PM agent:
08-22-2023 01:07 PM
It says my service is suspended
08-22-2023 01:05 PM
08-22-2023 01:02 PM - edited 08-22-2023 01:03 PM
Are you sure you're using the right 12 digit set of numbers? If you have multiple sets then use the one called PIN#. Also, wait an hour to try again. The system doesn't like more than 2 attempts per hour. It could also be that the voucher vendor has some sort of delay for using the vouchers. Some are more instant. Others have a delay.
Where did you get the voucher?
Adding - I was looking for the recording saying either your next renewal date and balance, or that the service is suspended, or that the number you entered couldn't be found.
08-22-2023 12:59 PM
Just says give me your 12 digit pin and still says we can’t not progress this request
08-22-2023 12:55 PM
From another phone dial 1-855-4pu-blic and tell us what it says. It will give one of three recordings.
08-22-2023 12:54 PM
HI @Destiny01
did you use a voucher and it didn't work? where you got the voucher from?
Try to login using Incognito/Private/Secrete mode and try again
Still not work, submit ticket with agent and they can add it for you
