iphone xs compatibility
mandogrl67
hi there, wondering if anyone is using a PM sim card in a new iphone xs, wondering if my sim will fit in the new phone!
Triguy
MoreYummy
Try to put your public mobile sim into one of them and see if it fits.  Smiley Happy
geopublic
@mandogrl67  PM's new sim card are tri-punch so you should be able to select the right size. If you card is old you might be able to get it cut, otherwise you can purchase a new card and do the change via selfserve.
Current PM SIM's are the tri-punch three sizes in one. These are standardized sizes. Would Apple actually have the audacity to force the entire market to change SIM sizes? Highly doubtful.
