internal text messaging
CHIGOZIE
I can't send text messages internationally. The error message i keep getting is "you have entered an incorrect number. pls try again". I am here in BC Canada. I made sure the country code is added yet it still doesn't work.
Need help ASAP. Thanks
10 REPLIES 10
CHIGOZIE
yes
dust2dust
And is there possibly a zero in front of any of the sets of numbers? If so don't use the zero in front.
@CHIGOZIE
Did you add the person in your contact list and add 011 234 xxx-xxxx?
Did you also try the + in front? Are you able to call in and out? Text in out anywhere else? Use your data?
CHIGOZIE
have tried all but didn't work
CHIGOZIE
It didn't work
CHIGOZIE
Country is Nigeria. Number ends with ....9406
darlicious
@CHIGOZIE
What country are you trying to text? Give us the number you are trying to text without the last 4 digits ( denote them as XXXX).
JL9
Where are you trying to text?
dust2dust
And the exit code? 011 or + in front of it all.
