04-13-2019 10:36 PM - edited 01-05-2022 04:21 AM
Hi there,
I just recently siwtched over to public mobile and things are going mostly smoothly, however while I can send MMS I can't receive them.
I tried following https://www.publicmobile.ca/en/bc/get-help/articles/set-up-data-on-an-iphone but am unabe to enter the details in the link as there is no MMS section in the specified settings.
- sending and receiving with my previous provider and same phone worked fine
- iOS is up to date
- MMS is enabled
- I did reset the Mobile Data network settings but still, no MMS setting section
If one of you have any ideas on how I can receive MMS texts, that's be neat.
Cheers!
04-13-2019 11:01 PM
Thanks, will do!
04-13-2019 10:59 PM - edited 04-13-2019 11:00 PM
@Martha1234 wrote:I kept my number from Freedom, it was prepaid then as well, outgoing and incoming calls work just fine.
I would send a message to the moderators to take a look, if it's been 3 days. To send a message to the moderators click here. In the private message to the moderator, include your Public Mobile Phone Number, 4 digit PIN, email address (used to activate your Public Mobile account), and an explanation of your problem. Response time is between a few hours up to 48 hours.
Moderator hours have been extended as of March 11th, 2019:
Weekdays 8am to 12am
Weekends 8am to 10pm (eastern time)
04-13-2019 10:55 PM
04-13-2019 10:53 PM
I switched 3 days agor from Freedom and I kept my number.
04-13-2019 10:45 PM
@Martha1234 , you can also read this post by @will13am for the same issue. See if it helps.
04-13-2019 10:42 PM
@Martha1234 wrote:Hi there,
- iOS is up to date
- MMS is enabled
Cheers!
You ported in your number from another carrier; was it a prepaid line, with which carrier? You're able to receive calls when people call your number?
04-13-2019 10:41 PM
- iOS is up to date
- MMS is enabled
Cheers!
How recently did you switch to PM ? Did you port over or select a new number ? Welcome to PM.
