iPhone - could not activate cellular data
Kalym
Hi, just back from overseas vacation where I used another SIM card.  Came back yesterday and put back in my PM card - now when I get onto the Internet I get error "could not activate cellular data network" even when I toggle the option on or off in my settings, and even put back in my vacation SIM card to try to make my phone recognize the PM card.
issue exists for mine and my wife's iPhone,
any assistence greatfully received
10 REPLIES 10
canadianrhythm
You, sir, are the knight who saved me from frustration. I had tried everything but could not get it to work. Your idea worked. Yay!
Kalym
When I looked at the cellular network settings, the only option I had was for personal hotspot so I couldn't do anything.  It got me stumped!
baijuxp
that is great. Resetting the carrier / network settings could work as well. There are preconfigured settings available on the internet as well. 🙂
Kalym
Yup, that was it, just delete the unused profile!
Kalym
I *think* I got it working... though I was trying everything so this may not be right, and will try on my wife's iPhone to confirm
go to settings / general / profile
in configuration file, delete any that you don't need ( in my case the UK sim I had )
then I think I rebooted and it worked.
thanks to everyone and will update when I confirm it
Kalym
Tried to reset the network settings and rebooted iPhone.  Did not work.  Can not activate cellular data network.
Thanks guys for suggestions, any others??
Kalym
Thanks for the suggestion, but under my network settings I only see hotspot information.
Will try the network reset option now.
i sometimes hate my iPhone so much
Kalym
i sometimes hate my iphone
srlawren
@Kalym I'd try a network reset, or maybe attach to iTunes to look for carrier updates?
@Rockdaddy22 @Luddite any other suggestions?
SD08
Assuming you've tried rebooting the phones already, have you checked to be sure your active APN settings have not changed?
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Setting-Up-Data-APN-On-Your-Ph...
