iPhone XR data not working
brettster99
I’m back hahaha.
Anyway got my new phone last night. Switched SIM cards and it automatically got signal etc. Today I tried to use data and it’s not working. It says public mobile and it’s says 3G but that’s it. I tried restarting / rebooting the phone to see if that fixed it. Nope.
Im going to try to text m friend to see if it’s just data or not
brettster99
Network reset plus turning off my VPN did the trick.
Thanks @gblackma
brettster99
@gblackma
Texting phoning works. Resetting network settings now
@brettster99
Maybe try network reset.  Toggle airplane mode on, then off.
Also, make sure that you did not run out of data in your self service account.
gblackma
@brettster99 reset your network settings and restart your phone if it doesn't. Enable data, sms amd mms and try to send an mms text message and to surf the net. Stay safe.
Reset network settings on Apple iPhone XR
  1. Tap on Settings from the Home screen.
  2. Next, tap General.
  3. Scroll down to and then tap Reset to continue.
  4. Select the option to Reset Network Settings.
  5. If prompted, enter the correct passcode for your device.
  6. Then tap the option to confirm network settings reset.
