iPhone SE 2 pre-owned technical specifications are incorrect
andre83
The iPhone SE 2 pre-owned product page has the technical specifications listed for the older generation iPhone SE. I ask Public Mobile to fix it so that the correct information is shown.
@andre83  good catch 👍 it's been updated
andre83
The iPhone SE 2 uses the A13 chip, but the specs on the Public Mobile product page say it has an A9, which was used in the older iPhone SE.
[👍 ... Luddite]
Timer
@andre83
report with a photos to support team by CS_Agent
LurganIeUk
What’s your point......be explicit.
