07-10-2022 01:33 PM
07-10-2022 03:31 PM - edited 07-10-2022 03:32 PM
I would think if you researched the best cost of data only plans and data+text+phone plans that the SIM will work in an iPad that has a SIM slot. Just don’t give out your phone number. Or you can use phone as a hot spot. Or try a friends phone SIM card in your iPad to verify. I have a PM SIM in a ZTE box....no issues with texts or unused data. Texts do show in my usage but I never see them and voicemail works.
07-10-2022 01:48 PM
Unfortunately not but if you do your research you can find some cost effective options relatively speaking as some companies out there really take pride in gouging as much as they can
07-10-2022 01:43 PM
No data SIM only from PM. Unless your ipad can work as a phone and has SIM slot.
07-10-2022 01:40 PM
@BDW if you want data only plan, check Fido, it is around $20 for 4 GB but they might ask you to have another line with it
Zoomers wireless and Primus both have similar tablet plan ($20 for 4GB) and no requirement to have another account to link with it. They might even give you a free entry level tablet if you sign up for 2 years
07-10-2022 01:37 PM
@BDW not unless you have a place for a sim card
07-10-2022 01:36 PM - edited 07-10-2022 01:36 PM
@BDW Sorry, no data only or tablet plan here. Plans here are not very tablet friendly ( I meant not cheap to use data only)
