07-23-2017 07:30 PM - edited 01-05-2022 02:29 AM
07-23-2017 08:10 PM
First: Turn off iMessage & Facetime then check Settings >> General >> About - if a carrier update is offered take it.
Second: Reboot your phone and turn on Factime, then go to Settings >> Messages >> iMessage on, Send as SMS on, MMS Messaging on >> Send & Recieve >> should show your PM phone number and your iCloud address. Confirm Factime also shows your PM phone number and iCloud address.
Third: Settings >> Cellular >> Cellular Data on, WiFI assist off >> Cellular data options Enable LTE on, Data Roaming on >> Cellular Data should show APN isp.mb.com
That should do it.
07-23-2017 07:34 PM
@blupenguin wrote:Hi my iMessage and Facetime will not activate:
- Have Data Plan with Public Mobile
- Have International Text with Public Mobile
- Using iPhone 5S Unlocked purchased from the Apple Store
- Can log into iCloud with Apple ID
Please help @CS_Agent
This is not an PM issue. You may want to contact Apple or just wait it out or restore phone. Have you tried it over wifi?
