i would like to get a sim card ang get a plan
02-27-2015 03:36 PM - edited 01-04-2022 12:34 PM
02-20-2018 01:50 PM
Select this link to buy a SIM card:
https://store.publicmobile.ca/products/triple-punch-sim-card?variant=5876039041
Once you get it in the mail (takes a couple of days), select this link to activate the SIM card:
02-27-2015 03:50 PM - edited 02-27-2015 03:50 PM
Enter your email when you click on order Your SIm, you'll be contacted if you're selected Beta Tester, when you receive your SIM ($0 charge), activate it and select your plan, you're ready to go with PM
