i need helping logging into my account
manjot1
i am not able to log into my self serve account
Staliger
@manjot1 Did you try Forgot Password function? Did you use your sign up email as username? Mods can restore your access. Contact them here: https://www.publicmobile.ca/en/bc/get-help/articles/contact-a-moderator
geopublic
@manjot1  Makes sure you are using the correct email  (Uppercase lock/Typos). If yes, then hit reset password link.
manjot1
i tried that, it says i am locked out i can't reset it
@manjot1 contact the moderators as the forgot password link failed. Ask them for a temporary password to your self service account.
There are 2 ways to contact the Moderator Team:
  • Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password.  Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen.  The mods answer will show up there.  When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
