08-01-2019 07:40 PM - edited 01-05-2022 08:28 AM
i want to get some add ons for the us but i can not remember my password or security question. or so it seems.
08-01-2019 09:01 PM
@douglas11 wrote:i want to get some add ons for the us but i can not remember my password or security question. or so it seems.
@douglas11 You can also purchase addon using the IVR system by dialing 611 from your phone.
08-01-2019 07:58 PM - edited 08-01-2019 07:59 PM
@ChuckYeah wrote:And check your email for accuracy or that it's the right one, forgetting both seems less likely than an issue with the original email?
If they are getting the question, unless they have more than one account, it's probably the right one
08-01-2019 07:47 PM
08-01-2019 07:45 PM
Contact @Moderator_Team
It can take up to 48 hours for the team to respond to your concerns.
Try logging in with another device. Perhaps you saved your password at some point.
08-01-2019 07:44 PM - edited 08-01-2019 07:46 PM
Hi
You will have to contact Moderators https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Provide your phone number and email you used for self-serve and if you remember the pin
