02-01-2025
04:46 PM
02-01-2025
05:16 PM
computergeek541
02-01-2025 05:21 PM
ok, thank you so much
02-01-2025 05:18 PM
hi @oana2 what ticket you are trying to cancel
if support ticket, wait for agent to reply and you can then reply and tell them to cancel
02-01-2025 05:14 PM
@oana2 if you do not respond to the support agent within 24hrs the ticket will be closed automatically but you can also wait for the support agent's message and then respond that you were able to fix it
02-01-2025 04:54 PM
Just wait until an agent replies back by dm and reply back that issue is solve.
