how do i send a private message
danielfrances
An agent asked me to provide a code received by SMS via private message.
2 REPLIES 2
dust2dust
Just go back in to the private messaging and click on that message from the agent and reply back with that code in the box below the message on the right side.
@danielfrances   did you get his message on your Community inbox?
If you did, just reply that message
or you can message CS_agent team using this link:
