hi
Tmeister2488
i need too transfer a # number 705xxxxx please help!!!!!!
Hi,
Are you porting into PM or are you porting out?
dust2dust
@Tmeister2488 wrote:
i need too transfer a # number 705-380-xxxx please help!!!!!!
Interestingly, it's a Telus Mobility # but the Koodo checker does not recognize it. Nor does the toll free account check. So it's either deactivated or the customer wants to port in.
dabr
@Tmeister2488    First use the down arrow top right of your post and delete your tel. number as you're posting on a public forum.
Are you trying to port in or port out your number.  A few more details would be helpful.
