getting in
toddmatheson
This is very annoying.
I need to speak with someone because it sends me into a circle.
I enter my phone number. It says I have already registered but when I try to recover password it will not recognize my email address.
Hi @toddmatheson , no stress, you can have CS Agent to look up your login and reset password
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. First type: "Forgot log in information"
  2. Then Click "Contact Us"
  3. Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
toddmatheson
Yes I see now. Note to self take the 5 minutes to troubleshoot.
RossN
@toddmatheson
hi contact a cs agent
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
type  request email and new password
2. alternatively you can private message them here
MrSpock
@toddmatheson you will need to contact customer support  to open a ticket, to speak to a customer service agent    Click here  you can send private message to a CS Agent here:  https://bit.ly/2GGCJzH check your community envelope for a reply
