08-26-2024 09:12 AM
08-26-2024 10:24 PM
hi @RUTHCO you can ignore that link. That was just a redundant post Oracle moved it away
for your case with Available funds, you don't need to do anything. PM will uses the fund for renewal. So, leave it there and it will be used on the next renewal
08-26-2024 10:20 PM
Link does not work
08-26-2024 10:20 PM
How can i use it
08-26-2024 11:46 AM
08-26-2024 10:55 AM
you don't have to explicitly do anything. It will be used for renewal.
08-26-2024 10:48 AM
I have $10 available and would like to use it
08-26-2024 09:18 AM
the Available funds can be used to buy plan add-ons like LD minutes or roaming add-ons
or if it is not used and renewal time comes, PM will first use the Available funds towards the renewal. If the funds not enough for the renewal, then PM will charge the remaining to your credit/debit card on file
