existing customer- adding another phone
defpernet
If I bring over another phone to public mobile is this considered being a new customer?  Would I get the promo?
@Master2001 wrote:
If you activate at Walmart, don’t forget to ask Walmart representative to add your first account referral code.
It can’t be add after.
It actually can be added afterwards by moderator, but it is a hassle.
Master2001
If you have a GMAIL account, you can use the same GMAIL account for all your Public Mobile account using GMAIL ALIAS.
Example, if your GMAIL addresses is [email protected] you can use it for your first account.
Second account use [email protected] (+ sign need to be there)
Third account [email protected]
All emails will go into Inbox of [email protected]
Master2001
pmmobile
@defpernet
Also, if you activate before Dec 25th you can also claim the 1GB data and 400 LD international minutes as well!
@defpernet  You will need a separate email address and it will have its own account. Wal-Mart is advertising a free SIM so other retailers will match and activate before xmas to be able to load free holiday add on gifts from pm.
darlicious
@defpernet  Absolutely! Add your referral code and you will get the bonus $20 credit too.
