Friday
- last edited
Friday
computergeek541
So I signed up to public mobile today and its been a Hassel. I thought my phone (samasung 20+) was compatible with the Esim but I guess it not. Now I cant get past the activation part in the app, so im stuck and cant do anything. Any help on this would be so amazing!!!
Friday
Thank you so much for the help
Friday
Check with , maybe they can send you the QR code to scan and install
open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
Friday
Thank you , I'm new to all this and I am so frustrated! I send a msg to that link you posted. Thank you
Friday
@LindsayMack007 yes S20 series might not be eSIM compatible with PM, you likely need to ask PM support's help. yoilu will need to message them and arrange
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened. CS Agent will reply to you there.
Friday - last edited Friday
@LindsayMack007 I have same phone and I have never been able to figure out how the esim works. Tells me it's not, but others says it is😯
Use the link below to get fu.rther assistance from Public Mobile.
