error porting a number
willis4892
At the end of the activation the app told me that something did not go right. Payment was made and porting was submitted. This was 2 days ago. should I s
2 REPLIES 2
willis4892
Thanks  softech
I am now in the process of waiting for a SMS from the original service provider. The Chatbot said to wait for 90 minutes. It looks like this may be a case for a higher level of support. The number i am getting is my work number with TELUS. So it's coming from a corporate account. I have my IT manager looking into it as well. Who said retirement was easy was mistaken.
@willis4892
try this,
  1. Click Logout on top left of the screen
  2. Wait 5 mins for the system to configure on the back end.
  3. Then log in again using the Email  and Password.
  4. The app will then  sends a code to the Email again,.  Enter the code
  5. and you will see the prompt  'Confirm for Full Access' and your Activation will be completed after
if that does not work, open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
