error message
dlapointe
When I try to call, out a message comes on saying I don't have calls on my phone. I signed up with PM in December and I've received this message 5 times now. I got the $40 package with data, call, and text. Why is this happening? I count on it working as it's my only telephone and it's important that it works at all times. I hope this is a temporary problem, otherwise I will need to change providers.
Yesterday, I dialled a wrong number, I got a message of something like UT8 your call cannot be corrected.
I hung up, and I dialled the correct number - it worked fine.
I've not experienced this on any regular frequency, however, it does happen.  Each time for me it's been a misdialled number, whether from my incorrect contact information, or a callback based on a missed call from an unknown number or if I've mistyped it myself.
If this continues, you will have better luck with the Modeterator_Team to address this issue.  Have you messaged them yet?
If you're that concerned about being able to make an emergency call - always carry a charged up phone without a SIM Card.  It will connect.
dlapointe
I don't have a dial tone, just the message and then it hangs up.When I try again in a few minutes , it's fine. Even this slightest interruption in service is not acceptable, as I could be attempting to make an emergency call.
hairbag1
If the problem persists, you'll need moderator assistance. Please be patient as response times are currently up to 24 hours or longer.
sandpublic
When this happens do you have coverage (signal)?
stonechucker
Ensure you're typing the number correctly, and if using a contact phone number, remove any non-numeric characters.
