10-08-2025 07:25 PM
i am trying to reach someone, but when i dial the number i get a 5ut1 error no incoming calls
10-08-2025 08:15 PM
thanks
10-08-2025 08:14 PM
PM is Public Mobile
They can re-provision the account , pretty much like refresh the account, to clear things up
10-08-2025 08:09 PM
PM? do you mean customer service? and what does re-provision mean
10-08-2025 08:07 PM
You can call Canadian number with a 1 too.
But ask PM to re-provision the account to resolve the issue
message them here:
CS_Agent will reply to your community inbox between 9AM-10PM EST (Mon-Sun), check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
10-08-2025 08:03 PM
my uncle is visiting in the states.. the acutal phone number is a candian number so if i put a 1 in front i get the message this is not a long distance call do not use 1
10-08-2025 08:00 PM
Usually a phone reboot would clear up. If not, try calling with 1 in front of the number and try calling without a 1 , one of the two ways should work
10-08-2025 07:52 PM
10-08-2025 07:35 PM
@munchvox Try putting a 1 in-front of the 10 digit contact and try again if all else fails you can ask support to investigate
