email
kckeng1
i changed my profile email and now cannot log into account
please advise
2 REPLIES 2
slusagm
To rule out if it is just a browser cache or app cache issue, please login My Account using browser with incognito mode
And try Reset password and login again
But if above don't help, then ask PM to sort it out
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
@kckeng1  You can try the forgot email option and see if you get code sent to it to log in , if still no luck get support to help you log back in
you can use the orange chat bubble bottom right of screen  or send  a  private message   To CS_Agent
