eSim
02-28-2025 02:00 PM
Will my eSIM, while connected to a local network for data, function in a country where Public Mobile does not provide coverage?
Service
02-28-2025 02:26 PM
@mni No you would not receive SMS messages on your Public Mobile phone number. You need to make alternative arrangements with your bank, CRA before you go.
02-28-2025 02:23 PM
SMS messages. My security codes for different accounts (bank accounts CRA etc).
Someone told me that if I purchase an eSim and travel to a country with no public mobile coverage. I connect to internet. Will I be able to receive text messages on my public mobile SIM there?
02-28-2025 02:20 PM
@mni You'll only receive text messages that work over wifi, you won't receive text messages that rely on your carrier, like SMS. So if it's SMS messages that you are looking for the answer would be no. If it's iMessages then the answer would be yes with reservations. What type of text messages are you concerned about? There are also MMS messages and RCS messages, so it depends on the type.
02-28-2025 02:15 PM
I have an eSIM, I'm in a country with no public mobile coverage. If I connect my phone to WIFI will I be able to receive text messages on my public mobile?
02-28-2025 02:02 PM
what you meant by " function in a country where Public Mobile does not provide coverage"?
PM sim card only work in Canada. Will also work in US or Mexico if you have Canada-US-Mexico plan
