eSIM transfers
trex1989
Hi All, I quickly wanted to check on this. If it’s get a new phone and would like to activate esim on that while deactivating it on my older device? How does one do that?
Is it possible to get a new esim for the next device?
Priority
Unfortunately not @Lijo, it must be a Public Mobile SIM Card. Telus SIM Cards are not compatible with Public Mobile.
If you need to buy a Public Mobile SIM Card you can do so directly from the Public Mobile Website or you can also order from Amazon.
Priority
They'll have no choice but to bring e-SIM to existing Public accounts when phones move to e-SIM entirely in Canada. I truly believe it is happening with the iPhone 15.
Alot of people buy new phones and use them with off Contract plans, like myself. Say I got an iPhone 15 and wasn't able to use it with Public Mobile because it didn't have a SIM Card slot I'd be very unhappy, so I think Apple will force Telus to work on that.
Fingers crossed, only a few months away. 🤞
Lijo
Can I use my old telus Sim card to do this?
trex1989
Thanks. Yeah I just made an account today and activate an esim. Hopefully they fix the esim solution since it’s likely the iPhone 15 may not have a sim slot and switching providers just to use the phone seems very odd.
Priority
Unfortunately e-SIM isn't available for current accounts, therefore If you need to transfer your e-SIM it is not possible. You'll have no choice but to switch to a Physical SIM Card until e-SIM Is introduced to everyone likely in September with the iPhone 15.
