06-22-2026 07:30 PM
I put eSIM on one cell phone now I removed it from that cell phone now want to put that eSIM on other cell phone how to do it
06-22-2026 07:46 PM - edited 06-22-2026 07:46 PM
If you can still login PM app, you can get a new eSIM yourself
download the app on your new phone and login. (If you have problem with receiving 2FA code, click "Didn't Receive code" or "Resend code" and choose either Send email or Send voice message)
Once logged in, Click Account from the bottom, then click Purchase SIM Card and select eSIM.
Once it confirms your phone is eSIM compatible, click Pay $ and Install
but if you have trouble logging in the PM app, you will have to ask PM support to assist. Private message CS Agent at:
06-22-2026 07:37 PM - edited 06-22-2026 07:38 PM
Since you're moving your eSIM to another phone within the 15-day window, there is a $5 charge to reissue it. This fee is waived if you wait until the 15 days are up. However, if you need to switch right away, just download the app on the new phone to download your new eSIM for $5.
