eSIM not activating
BritneyAnna
Previously with Freedom - I receieved on activation error message on my iphone xs and it says not able to activated sim can someone help me.
@BritneyAnna   they should be able to resend you the QR code.  Message them and get it sorted out
and remember to come back and tell us how it turns out.  It is a new process and we all eager to know how the activation experience is 🙂
BritneyAnna
Yes I did. and then an error popped up.
pmbc
@BritneyAnna You can reach out to the CS Agent directly using this link,
This will send them a private message and they will reply back to you.
@BritneyAnna
did you get to the stage to install the QR code for eSIM profile?
look like PM is struggling eSIM activation with iPhone at the moment.  Likely it can be resolved, but need a ticket with PM support.   Please message them here:
