e sim to physical sim
Noona8
I purchased an e sim, i want to use a physical sim to be able to switch the device, is this possible?
2 REPLIES 2
Noona8
thanks, I am hoping I will be able to switch device and eventually transfer my number from another provider.
kb_mv
@Noona8 Go buy a Sim card at a Koodo/Telus store or from Amazon. Then go into your app under account and select "change your SIM card". You then enter the number from the new sim and everything transfers from old to new. Easy peasy.
