do I get charged for texing 5132?
sahands
I was forced to send a text to 5132 in order to stop pm from spamming me, do I get charged for sending the unsubscribe text?
I do not have unlimited texting plan.
szymon247
If you aren't on a texting plan and it went through, you won't get charged extra. If you don't have a texting plan, you simply wouldn't be able to send that text. There are no "pay-per-use" fees, so there's no way you could be charged for that text.
I'm almost certain that sending an outgoing "stop" message to this number will count as one of your outgoing text messages.
MacMe
Just noting that if you have the $10 (50 minutes/50 texts) plan, incoming texts are free.
NDesai
Not sure about that, but you can login to your self-serve account to see if it used a text from your limit.
