data use problem
Gigitos
Hi!
I have 6GB on my plan (for 3 months) plus last month I got a text saying I got an extra GB... i'm 90% of the time on a wifi! how come I "used" all my data??
geopublic
@Gigitos  Maybe WiFi was down and you did not realise it. Check your phone's data built-in data usage app you determined if that was the case.
If you still feel there was a problem then best to submit a ticket to PM for further investigation.
To submit a ticket to Public Mobile do the following: PMST.png
popping
@Gigitos wrote:
Hi!
Check the data usage line on your overview page after login.
I have a 5GB plan with the 1GB bonus data.  I had used 697MB of my 1GB bonus data.  I used 1237MB out of my 5GB plan data.  If you don't see these lines, you have used all your data.  What is showing in your overview page?
  • Data & Add-OnsAmount Used
    1GB Promo
    697.544  /  1024 MB
    5GB at 3G Speed
    1237.345  /  5120 MB
Triguy
Check your phone settings to make sure you don't have auto updates for apps.  Also if you use google maps to only enable while on wi-fi.  You can log into your account under view usuage to see when and how much data was used.
