data on phone isnt working
nigmea
hey just got public mobile yesterday and data isnt working. Lg-G3 things ive done
*factory reset of course reboot
don't have another phone to try so couldn't
tried conneciton/ regrestration automatic
not sure what else to do thanks
truckkarr
nigmea
I have data hurray! thank you all
LEGO
@nigmea Try this settings:
Please, create a new Public Mobile APN, don’t edit an existing one, reboot after.
nigmea
this is what i used for lg-g3 odd thing is it wont save these setting.
edit** Resetitng phone aha then ill attempt freshly adding apn settings and post back. I'm sure its what i need to do thanks
Freedom Internet APN settings
Open App Drawer and go to Settings Mobile network settings Access point names
Press button on top right corner.
Enter name: Freedom 1
APN: internet.freedommobile.ca
Proxy:
Port:
Username:
Password:
Server:
MMSC:
MMS Proxy:
MMS Port:
MCC: 302
MNC: 490
Authentication type:
APN type: default,supl
Keep default values for all blank fields shown above.
Press menu button (top right) and select Save. Done.
will13am
@nigmea, I suspect that the APN settings may be what is affecting your ability to use data on the phone.  Please review this link and set up the Public Mobile APN on your phone.  After that, make sure mobile data is turned on.  Good luck.  Report back results.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-up-Data-APN-on-your-phone/ta-p...
mimmo
Lg's are known to need a factory reset, did you set up the apn settings after the factory reset?
